column lock service
Old Jun 28, 2010 | 09:38 PM
kkdann's Avatar
kkdann
Cruising
Default column lock service
I started my car the other day and got the service column lock on the display.
I ordered a column lock bypass and installed it.
I also reset the body control mod. by removing the
two fuses 25 and29 everything tuned out ok.
It drove fine untill i shut it off and started it again
and the problem started all over again.
I have tried to reinstall the clb and reset the bcm
sometimes it will do the same thing or i will get the
service column lock.
Can anyone help me on this one
thanks dan
Old Jun 28, 2010 | 09:52 PM
chev03SSR's Avatar
chev03SSR
funny you say that.. most of my cl problems started after i changed my starter.
Old Jun 28, 2010 | 10:04 PM
kkdann's Avatar
kkdann
Cruising
It is a 99 manual and the bat. voltage is 12.67 off and 13.78 on.
at the starter not sure
Old Jun 28, 2010 | 10:18 PM
kkdann's Avatar
kkdann
Cruising
Ok right now iam getting 12.7 key off volts at the bat. do you think
that is low
Old Jun 28, 2010 | 10:26 PM
kkdann's Avatar
kkdann
Cruising
no i did not remove the k harness not sure if there is one, but i will
check it tomorrow
thanks for the info
dan
To column lock service
