My wife's C5 is showing B0332, B0337, B0361, B0365 which are all HVAC and say there's a short to ground. I'm not sure where this ground is or where to go from here. I appreciate any help.
The codes all suggest a "short to ground", which could be anything metal tied to the chassis, or any wire connected to ground. The inside and outside air temp sensor, and the LH and RH actuators all use a 5 volt reference voltage from the control head itself. Each of the aforementioned, have individual circuits, so I believe you have two possibilities:
1) A seriously damaged control head connector harness(not likely, and all four signal wires would have to be shorted to ground)
2) An internal short in the control head itself.
Wow thanks for the excellent diagnosis! I'll get to the control head and see what it looks like.
