LS2 into C5 questions
Old Jul 1, 2010 | 07:36 AM
99FRC Newb's Avatar
99FRC Newb
Default LS2 into C5 questions
its out of a 2005 GTO, so it has the 24x reluctor fortunately.
is my list of things complete that i need to do?
LS1 to LS2 TB harness
Knock sensor extension harness
Cam position extension harness
MAP sensor extension harness
Drill out the side bolt holes and tap for your knock sensors
Cut out a lower bolt boss to clear your engine mount
Oil pressure sensor harness to extend 2 inches
will my LS1 pan bolt up?
also, its a long block with no accessories. will i be able to swap my accessories over? or do i need to get LS2 accessories?
and any vendors wanna hook me up? haha.
Old Jul 1, 2010 | 08:08 AM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by 99frc newb
its out of a 2005 gto, so it has the 24x reluctor fortunately.
Is my list of things complete that i need to do?
Ls1 to ls2 tb harness
knock sensor extension harness
cam position extension harness
map sensor extension harness
drill out the side bolt holes and tap for your knock sensors
cut out a lower bolt boss to clear your engine mount
oil pressure sensor harness to extend 2 inches Contact TPE. Use their ops extension kit. Puts it down by the filter. Easy access.
will my ls1 pan bolt up? Yes
also, its a long block with no accessories. Will i be able to swap my accessories over? yes or do i need to get ls2 accessories? no
and any vendors wanna hook me up? Haha.
You may need individual injector wiring adapters. Depends on your setup, etc
btdt
hth
Old Jul 1, 2010 | 05:09 PM
99FRC Newb's Avatar
99FRC Newb
any vendors out there sell a kit for this?
i know TSP sells it with their engine packages, but do they sell it seperate?
Old Jul 1, 2010 | 05:16 PM
Pony327's Avatar
Pony327
sounds like a cool project let us know how it works out... why not get a LS3 if your going through all that trouble better heads more power etc...
Old Jul 2, 2010 | 10:19 AM
99FRC Newb's Avatar
99FRC Newb
because i bought it from a guy on here for an incredible price
Old Jul 2, 2010 | 11:13 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Yeah, I saw that motor and was tempted to buy it too. I just don't have anymore space in the garage until I sell off a bunch of parts and finish repair the transmission in my Grand Cherokee.
Good Luck with the build. Some guys notch the motor mounts when fitting them up.
You can get the needed harnesses from Caspers. I would swap out injectors to LS1 style to make the swap easier.
Old Jul 3, 2010 | 10:36 AM
c5inphila's Avatar
c5inphila
The pan will bolt up, you must use your oil pick uo too.You must use your c5 accessories and harmonic balancer.
Old Jul 3, 2010 | 12:38 PM
99FRC Newb's Avatar
99FRC Newb
yeah, i really lucked out that it stayed for sale so long!
why do the LS1 injectors make it easier?
sweet. i have a powerbond from my old motor and i wanted to put a 2 piece timing cover on it for future cam swaps.
Old Jul 3, 2010 | 01:49 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Because they are plug and play, elsewise you'll have to buy adapter clips.
Why would you swap accessories as the Ls2/Ls3 stuff will work too, except for the alternator and A/C. They use the same alternator bracket.
Old Jul 3, 2010 | 10:36 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
Yeah, that was a great deal you got. I was seriously considering that one too. Will be fun to see how this turns out for you.
Old Jul 3, 2010 | 11:35 PM
Nysbadmk8's Avatar
Nysbadmk8
Its an easy swap..
Just did it in mine..
Old Jul 4, 2010 | 05:59 AM
99FRC Newb's Avatar
99FRC Newb
i probably won't run A/C (i always roll my windows down) and my PTK kit runs a different alternator anyway. thats convenient. haha
Old Jul 4, 2010 | 09:15 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I would put it in, just in case you move or sell the car as most buyers would want A/C.
Old Jul 4, 2010 | 09:25 AM
c5inphila's Avatar
c5inphila
He has the accessories from his ls1.
Old Jul 4, 2010 | 09:28 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The water pump is lighter and thinner pulley, the Power Steering Pump has a metal pulley with slots in it for easy access and the bracket is stronger.
Old Jul 4, 2010 | 09:41 AM
c5inphila's Avatar
c5inphila
Today 08:25 AM
How much do you think that would cost? For somthing that probably dosn't matter if his are in good shape.
Old Jul 4, 2010 | 09:44 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Today 08:25 AM
Just really depends as there are many good deals out here in this economy.
Old Jul 4, 2010 | 09:53 AM
c5inphila's Avatar
c5inphila
Today 08:41 AM
True, but like my father taught me" if it ain't broke don't fix it". He probably wasn't the first one to say that.
Old Jul 4, 2010 | 10:15 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Today 08:41 AM
To each their own, I would rather do right once than to keep going back as I have better things to do with my time.
To LS2 into C5 questions
