cleaning maf........................
Old Mar 22, 2002 | 06:22 PM
rayjerman's Avatar
rayjerman
Default cleaning maf........................
i seen a topic a while back where someone cleaned their mass air flow sensor and it picked the car performance up. just wondering if anyone has done this and how do you do it without damaging anything. my car is running good, i am just curious. it makes sense to keep it clean though. thanks. :chevy
Old Mar 22, 2002 | 09:15 PM
bparker's Avatar
bparker
Default Re: cleaning maf........................ (rayjerman)
use rubbing alcohol and q-tips.. be VERY careful around the electronics..
BP
Old Mar 23, 2002 | 01:35 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
yup, be careful when you clean that thing. The element is in the middle of the MAF, that is what you need to be careful of :yesnod:
Old Mar 23, 2002 | 06:54 AM
MiamiDave's Avatar
MiamiDave
Default Re: cleaning maf........................ (pkmoose)
I've done it, and it worked. I have a vortex cold air and a Granatelli MAF, which has no screen and is a wide open element. Be wary of brand new high flow (oiled) filters for maybe the first 5K, and if you've recently cleaned and reoiled (especially if you think you've over-oiled). Minute particles of oil get sucked through and put a fine layer of grime on the wires, and can confuse readings.
To cleaning maf........................
