Electrical Issues ...
Old Jul 2, 2010 | 06:05 PM
dman7441's Avatar
dman7441
Default Electrical Issues ...
Was cruising down the road and lost ABS, TCS, oil pressure, fuel level, and engine temp. The radio turned off, my passenger side door power windows and locks didn't function, I recieved reduced engine power but the engine ran normal. Pulled over turned the car off and then back on and all indications went back to normal but my passenger side door still did nothing and I honestly don't remember if the radio was on or off ... i hadn't realized it was off yet at this point honestly but i'm sure it was ... i was a little freaked. Go a few miles and everything else fails again. Decide to drive it home. On the way back home ... which wasn't far, all my indications come back radio comes back on and everything works normally again ... haven't driven it much since then so can't say if it is recurring.
Today was going to go to a bbq and back out of the driveway turn the car off because i forgot something go back out turn the car back on ... steering column lock ... yes i have the bypass installed, check fuse 25 and a fuse checker says it's good but i replace it anyways, after an hour of fiddling around chasing wires and so on ... solves the problem.
My question is would blowing fuse 25 cause all the other **** ... or if i have seperate issues I should be worried about.
Old Jul 2, 2010 | 08:51 PM
dman7441's Avatar
dman7441
Cool beans, have yet to check batt voltage and didn't delve quite deep enough into bill's post for the door thing, I don't know if that's what the problem was but I suppose I did pick my brother up right before this happened so the passenger door was opened. Obviously I'll be back if the issue/s resurface hah.
Do you have corvetteforum memorized lol? Your guidance is most appreciated, I see your hand in many threads and words just don't do your helpers and pointers to others info justice.
