Faster coolfans
Old Jul 4, 2010 | 01:31 PM
hotparts's Avatar
hotparts
Default Faster coolfans
Hi guys,
do you know a more efficent coolfan kit for the C5 or replacement cooler engines for the stock ones?
I have a little thermic problem with my blower, the cooler is bigger so i don`t have more space!
Thanks for help
Old Jul 4, 2010 | 01:42 PM
hattitude's Avatar
hattitude
When I installed my blower, I installed the DeWitt's C5 radiator along with the C5 fan upgrade....... I have no temp problems in the San Diego summers...
http://www.dewitts.com/pages/product...asp?ProdID=320
http://www.dewitts.com/pages/product...asp?ProdID=378
PS- make sure you clean your radiator & condenser. You'd be surprised what they accumulate.....
Good Luck.....
Old Jul 4, 2010 | 01:43 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Not really--i would install a colder thermostat like a 160* and set the fans to come on earlier --like #1 on at 190 off at 185---#2 on at 200 off at 191
Old Jul 4, 2010 | 01:55 PM
hotparts's Avatar
hotparts
i already changed the radiator to a bigger one put the colder theromostat and removed the climate radiator.
attitude
The coolfans look nice but do they need more space and do they work with the original harnesses? The fans llok a little bit deeper?
They really have the double capacity?
Old Jul 4, 2010 | 05:00 PM
hattitude's Avatar
hattitude
attitude
They were an easy swap with the OEM fans. They come with OEM style plugs that just make them plug & play.
I don't doubt that they have double the capacity. The first time they kicked on when I was out of the car, I thought a plane was going by..
They appeared to be the exact same size. I didn't actually think to compare them, so I can't say for sure. They are bigger in diameter than stock, but I don't knw if they are any deeper. I have a KB blower, so nothing really affecting the space in front of my engine. I had no trouble fitting them.
Might give DeWitts a shout. They should know........
Good luck....
To Faster coolfans
