4L60E question
Old Jul 5, 2010 | 11:03 PM
RTDillon's Avatar
RTDillon
Default 4L60E question
Is it possible to bolt a bellhousing from a camaro 4L60E to a covette transmission? (Change input shaft, etc.) If not, is it possible to bolt the C5 differential to a camaro 4L60E case? (Change output shaft, etc)
In case it is not obvious I am looking into a mid engine application. I have not been able to find any useful information online other than photoshopped pictures.
Old Jul 7, 2010 | 07:47 AM
RTDillon's Avatar
RTDillon
For what it's worth, I have been calling aftermarket manufacturers and so far have been told that I can bolt the front bell housing from a standard 4l60e transmission to the covette model and that the input splines of the corvette 4l60e match up to a LT1 torque converter.
Reality check please. Does that sound right to you folks? I know this combination will be long for a car but this will go into a v8 trike so the length is actually an advantage.
What do you think? 400 hp, 1000 pounds and only 1 seat.
Old Jul 7, 2010 | 08:46 AM
Solofast's Avatar
Solofast
Talk to the guys at Mongoose Motorsports. They have bolted together something similar for their mid engine Corvette GTP car. I'm sure they can tell you what works.
To 4L60E question
