Active Handling Issue - Please Help!
Old Jul 6, 2010 | 04:17 PM
Gromzzz's Avatar
Gromzzz
1st Gear
Default Active Handling Issue - Please Help!
I have a 2004 Corvette with 29,000 miles on it. I've had it since 04 and I started driving it more recently last month. Here's my problem. For about a month or so, when I'm driving the Corvette on the freeway (going over 65+) my Active Handling will pop up on the dashboard of the car. I can feel the car move slightly (sometimes jerk) to the left for a split second, then re-correct itself. This was only happening sometimes on the freeway. On the 4th of July weekend, I was driving about 120 miles on the freeway and the car was jerking almost every 10 seconds. The active handling would pop, then it would go away, pop, go away, on and on again. While I was driving home two days after this happened, the light popped on while I was cruising on the freeway. Service Active Handling. It is on the screen now and I called the dealership. They told me to bring it in, but after reading the manual and horror stories about having to pay a ton of money (my car is no longer under warranty) I figure I would post here. I read in the manual that I can just turn off the active handling. Would this be recommended? Please give me some insight! Thanks in advance.
Old Jul 6, 2010 | 05:27 PM
87SAM's Avatar
87SAM
Yes, you can turn off the Active Handling. Secondly you need to check for trouble codes to see what the problem may be.
http://web.archive.org/web/200306051...D=26&TopicID=1
Old Jul 6, 2010 | 09:06 PM
HNDRKSS's Avatar
HNDRKSS
That link was awesome! That will be very useful.
To Active Handling Issue - Please Help!
