C5 door panel arm rest wrinkles
Old Jul 6, 2010 | 10:29 PM
shaniac1973's Avatar
shaniac1973
Cruising
Default C5 door panel arm rest wrinkles
Now i'm just getting whiny with this issue, is there a fix for those arm rest wrinkles where the adhesive failed to stick to the door? Its a show car, and needs to be repaired or replaced.
Can they be glued back?
What glue?
What method?
buy new ones?
Old Jul 6, 2010 | 11:49 PM
jrose7004's Avatar
jrose7004
It's a common C5 problem. Some cover them with stick on arm rest others try and reglue with a hypo needle.
Old Jul 7, 2010 | 12:24 AM
jornahow's Avatar
jornahow
Now I've heard of everything - Botox injections for my sagging Vette
Old Jul 7, 2010 | 07:22 AM
gdaddee's Avatar
gdaddee
I tried regluing also. Didn't work. I bought the stick on arm rests but the wrinkles were too bad to cover. So I made a template of the bottom of the new armrests, just a little smaller. I cut out some 3/16 fiber board using the template, and screwed it down to the old armrest taking out all the wrinkles. At first, I used the double tape to try and stick the new armrests to the fiberboard, but it wouldn't hold. I then used silicone glue and hot glue to attach the armrest. The hot glue held the armrests securily while the silicone glue set. They are still holding with temps outside in the upper 90's.
Old Jul 31, 2012 | 02:11 AM
meanjoe's Avatar
meanjoe
Default Arm rest
I bought a new door panel from the dealer for $600.00 and 3 months later it looked just like the old one. What a rip off! I've also been to two different trim shops and they both looked at me like a deer in the headlights. Somebody out there must know of a good fix for this issue?
Must be a common problem for all C5's. Interior is perfect except the dam arm rests. Ideas please.
Old Jul 31, 2012 | 08:40 AM
RichAshley-Black99's Avatar
RichAshley-Black99
Here you go looks like this worked pretty well
http://forums.corvetteforum.com/c5-g...up-how-to.html
Old Jul 31, 2012 | 09:19 AM
3boystoys's Avatar
3boystoys
Take the panels off, strip the old vinyl off and have them recovered if you want perfection.
To C5 door panel arm rest wrinkles
