Corsa Exhaust Installation help......
Old Mar 23, 2002 | 09:01 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Default Corsa Exhaust Installation help......
Just ordered a set of Corsa Indy's with Pro tips, and I will be installing next weekend! Does anyone have any tips or tricks or anything I should know before tackling this job next Saturday 3/30? I can't imagine that it will be very hard. I haven't been able to find any help in Tech Tips. If anyone has anything they think I should know please post! Thanks! Can't wait to get these things on! :chevy :D :)
Old Mar 23, 2002 | 10:46 AM
pdm's Avatar
pdm
Default Re: Corsa Exhaust Installation help...... (Glennm27)
I had my Pro Tips installed on my '99 at a local muffler shop a little over a year ago. I've read threads on this forum where the old exhaust could not be removed in one piece (you couldn't get it over the axle). At the muffler shop, they tried as well and also could not get the old exhaust off without cutting it.
Putting on the Pro-Tips is different since it bolts together where the old system was all welded. My advice is to take it to a local shop with a good lift, unless you've already got that and a welder. It cost me $75 and was well worth it. I also had them install a X-Pipe and I highly recommend them. You still get some burbling on de-accel but not enough to be offensive. To me, it sounds perfect.
Good Luck and enjoy it.
Old Mar 23, 2002 | 10:48 AM
YO-EL's Avatar
YO-EL
Default Re: Corsa Exhaust Installation help...... (pdm)
If you swing down the rear sway bar you can remove the stock system in 1 piece for both sides. That is the only tip needed. :yesnod:
Old Mar 23, 2002 | 10:54 AM
72 LT-1's Avatar
72 LT-1
I did my install of my Corsa Touring system myself. Very straightforward direct bolt-on installation. The only thing you MUST ABSOLUTLEY HAVE is a lift. The car MUST have at least 30 inches ground clearance to swing the old system out, unless you want to cut the stocck pipes.
The whole job took less than an hour. Good luck.
Old Mar 23, 2002 | 11:28 AM
Glennm27's Avatar
Glennm27
Default Re: Corsa Exhaust Installation help...... (72 LT-1)
Thanks for the tips 72 LT-1 and Ellis! Yea, I've heard where I have to loosen the sway bar. I think you guys just told me all I needed to know. Loosen the bar and how much clearance I needed. I do NOT have a lift but I can get the car up enough. I don't want to cut anything! I'm sure with enough clearance I'll be able to get them outta there without cutting. Thanks again! :D
Old Mar 23, 2002 | 11:36 AM
CarolinaC5's Avatar
CarolinaC5
I had mine put on at a shop to. I paid around 65 bucks. I couldn't imagine doing it without a lift. You really have to wiggle the exhaust around to get it over the rear axle. Search the archives, I remember somebody posting instructions/tips for the installation awhile back. You'll love them once you have them on.
Good Luck!
Tom
Old Mar 23, 2002 | 12:04 PM
C5Noir's Avatar
C5Noir
This is all you'll need, go to this site: http://www.chazcone.com/corvette/corsa/
Old Mar 23, 2002 | 12:07 PM
Speed-Racer's Avatar
Speed-Racer
Default Re: Corsa Exhaust Installation help...... (C5Noir)
I would probably have a shop do it. On the A4's it's harder as you need to remove the heat shields on some years. Then it's a tight fit.
George
Old Mar 23, 2002 | 04:46 PM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
As mentioned the stock exhaust can be pulled down without cutting it. The passenger's side is the hardest to get down. You have to pull it back, rotate down and to the side and then call it a few names before it slides out. The Corsa will go right in with no problem and can be bolted up with a 15mm deep socket.
Tom
Old Mar 23, 2002 | 08:49 PM
Arkay's Avatar
Arkay
The best money I have spent was to have a pro install the Corsa
Indy system. There are tricks you learn by doing and he knew all
of the tricks.
Old Mar 23, 2002 | 09:01 PM
Greg00Coupe's Avatar
Greg00Coupe
Default Re: Corsa Exhaust Installation help...... (Dick Kriss)
Do it yourself.... nothing like the satifaction of a job well done.....
Old Mar 23, 2002 | 09:15 PM
rick g's Avatar
rick g
Default Re: Corsa Exhaust Installation help...... (Greg00Coupe)
I installed mine, the trick is if you can't get it raised 30" off the ground you will have to cut the original off. I used two floor jacks to raise mine and it took about an hour.
Old Mar 23, 2002 | 10:04 PM
The Black Knight's Avatar
The Black Knight
Default Re: Corsa Exhaust Installation help...... (rick g)
Do it yourself -- it's really not bad at all.
With the car up high enough, loosen the sway bar bolts and swing it down out of the way. On the automatic cars, remove the heat shield just forward of the passenger side axle assembly. Loosen the bolts holding the muffler pipes to the H pipe, and then remove the the rear hangers. Tom Byrne is right, the drivers side comes out very easily, but the passenger's side is harder. I put a small pry bar in the H pipe on passenger side and gently pulled it down about 2 inches, enough to get the clearance needed to get the muffler pipe above and over it (you'll see what I mean when you do it, the flange on the muffler pipe hits the H pipe that it needs to clear.) Then twist the muffler pipe out and down. You do not have to cut anything if you don't want to.
The Corsa's will go back on much easier due to separate components and no twisting. Make sure you put the pipes that connect to the H pipe over the axles first before putting the sway bar back up.
Total time from jacking up to jacking down was one hour (and yes, we did cuss a little until we used the pry bar trick.)
Good luck.
Old Mar 23, 2002 | 11:17 PM
geck's Avatar
geck
Just installed my Corsa indy w/ pro tips today. I pulled the car up on ramps and jacked up the rear and set it on jackstands. You should be about 58" from the floor to the top of the lip above the 3rd brake light. You do not have to cut the stock exhaust. Each side comes off in two pieces(the pipes and the muffler). You need the height to be able to swing the pipes around the sway bar(which you must loosen). Do your self a favor and have a friend give a helping hand. It is not a job you want to do by yourself.
Glennm27's Avatar
Glennm27
Default Re: Corsa Exhaust Installation help...... (The Black Knight)
Thanks to EVERYBODY who responded! I appreciate your comments! I am going to do it myself. I can get some pretty hefty jack stands from the guys in our shop! I work for a trucking company and they have some big time stands down there (sure wish they had a lift). Sounds like if I can get 30" I'll be home free! The pry bars and cussing are all part of the fun and expected! Nothing a few Budweisers can't help me overcome! Thanks again guys! :cheers:
To Corsa Exhaust Installation help......
