install remote clutch bleeder without drivetrain drop...is it possible?
Old Jul 7, 2010 | 03:35 PM
PetersC5's Avatar
PetersC5
Default install remote clutch bleeder without drivetrain drop...is it possible?
I'd like to install a remote bleeder while I'm replacing my leaking clutch master. My clutch is fine @ 28k miles and I dont want to pull the drivetrain until its time for a clutch or other necessary repair.
Is it possible, impossible or too much trouble to do unless your doing a clutch.
I read a few old posts and a couple of folks made special wrenches etc but I am hoping that someone has come up with new bleeder hardware that will allow it.
Thoughts appreciated......
Old Jul 7, 2010 | 04:58 PM
wcsinx's Avatar
wcsinx
Bump because I would like to know as well. I've heard more than one person claim they just stick a wrench on the bleeder without removing anything, but I'll be damned if I can figure out how.
Old Jul 8, 2010 | 08:11 AM
PetersC5's Avatar
PetersC5
Can we get any of the remote bleeder manufacturers to weigh in....
Who makes a bleeder that you can install without drivetrain drop???
Old Jul 8, 2010 | 09:05 AM
Atok's Avatar
Atok
I installed mine without dropping the drivetrain. I had to fabricate a wrench. Without my custom wrench it was impossible to ensure the fitting on the slave was tight. Removing the old bleeder wasn't an issue, you can get a 1/4" drive socket on it. Also, by removing the clutch cover you can easily see what you are doing so visibility is not a problem. If you have big hands don't even bother trying. The key is a custom wrench to tighten the fitting and even with such a wrench it's difficult to get a good feel for the torque you have on the fitting. It's risky but worked out for me.
Old Jul 9, 2010 | 05:49 PM
Red3644's Avatar
Red3644
Default Custom wrench...
Can you give us some hints about your custom wrench?
Old Jul 10, 2010 | 12:01 AM
jgump's Avatar
jgump
Old Jul 10, 2010 | 12:18 AM
Kotlas's Avatar
Kotlas
Probably involves a Craftsman wrench and a blowtorch
Old Jul 10, 2010 | 08:06 AM
Patches's Avatar
Patches
FWIW, here's a doc I saved quite a while back that details how one member made a tool to install his remote bleeder.
File Type: doc
Old Jul 10, 2010 | 11:11 AM
Zmeister's Avatar
Zmeister
Thanks Patches. I'm going to take that file to work on Monday so that I can open it with Word. Looks like it may have some pictures in it...at least I'm hoping it does.
Either way it's great, helpful info.
Old Jul 10, 2010 | 11:50 AM
Atok's Avatar
Atok
I didn't save the wrench once I was sure I had no leaks.
Basically, all I did was take a 6-point box end wrench and cut the box end off. I then welded it back together at a 90* angle. I had to cut and weld because bending does not give you the slim profile needed. Obviously a good weld is critical. I then heated and bent the wrench about 1" up from the now 90* box end. So the wrench now looks like an "S". Finally, cut a notch out of the box end just big enough for the remote bleeder hose. So now you've got an "S" shaped fitting wrench.
It's important to use a 6-point box end to reduce the chances of slipping and rounding the remote bleeder fitting.
Old Jul 10, 2010 | 12:25 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Try the attached.
I converted Patches' Word doc to a PDF for people that don't have Word installed.
Nice to have.
Take #2. I didn't notice that some of the photos ran outside of the margins so I resized them a bit.
File Type: pdf
Old Jul 10, 2010 | 12:30 PM
Zmeister's Avatar
Zmeister
Thanks Blue 92!! Much appreciated. I'll give that file a try.
Old Jul 10, 2010 | 12:40 PM
Blue 92's Avatar
Blue 92
Download it again. The photos in the first one run off the page. The one there now has them resized to print correctly.
Old Jul 10, 2010 | 04:23 PM
PetersC5's Avatar
PetersC5
Thanks guys
Appreciate the feedback and the word / pdf files. Great job the originator did on the tools and documentation
Just got the master cylinder in yesterday and will give the remote bleeder a shot in the near future.......
Old Jul 10, 2010 | 06:10 PM
Patches's Avatar
Patches
Originally Posted by Blue 92
Try the attached.
Nice to have.
Guess I should have done that conversion first. Thanks.
Old Jul 11, 2010 | 10:23 AM
Zmeister's Avatar
Zmeister
Thanks again Blue 92! Downloaded the new version and it's perfect!!
And, of course, thanks again to Patches for the original file!
Great stuff.
Old Jul 11, 2010 | 11:08 AM
Blue 92's Avatar
Blue 92
Great stuff.
Patches did the work.
All I did was click here and there a few times.
To install remote clutch bleeder without drivetrain drop...is it possible?
