DIC Codes - Any Usual Suspects?
Old Jul 7, 2010 | 06:42 PM
Kevin G's Avatar
Kevin G
Default DIC Codes - Any Usual Suspects?
DTC P0442 Evaporative Emission (EVAP) System Small Leak Detected (H and C) Could this be the gas cap?
DTC B2605 Seat Front Vert. Position Sensor Failure (H and C) I suspect this has something to do with my power seat memory and it's ability to move the seat to proper position? The memory function still seems to work fine.
DTC P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage (H) Note historical only, after numerous current codes last summer I replaced the sensor over the winter. I included this for anyone else who might run into the same code.
