Please help!!!! I installed clb still getting errors
Old Jul 7, 2010 | 09:03 PM
jetstreamC5's Avatar
jetstreamC5
Default Please help!!!! I installed clb still getting errors
I installed the clb from Corvettes of Houston and I'm still reading errors and I've tried everything posted on the sticky thread above what do I do now ?
Old Jul 7, 2010 | 09:30 PM
DIXZ's Avatar
DIXZ
What do you mean by: "I'm still reading errors" ?
Old Jul 7, 2010 | 10:09 PM
jetstreamC5
Pull key wait 10 sec and still having fuel shut off over 2 mph
Old Jul 7, 2010 | 10:13 PM
jetstreamC5
Originally Posted by 8VETTE7
OK so lets start with some basic information. Car is a 99 from your profile but Auto or manual??
Did you check for and remove a GM K Harmess?? It would look like this:
http://forums.corvetteforum.com/c5-g...l-locking.html
Then scroll to post #8
It would have been installed in series between the actuator male connector and the female connector that is attached to the bottom of the dash? If present BOTH ends need to be disconnected. If your CLB is plugged into a female connector that has only 2 wires, one white and one purple, then you plugged tthe CLB into the K Harness and that will not work.
Have you cleared all codes in the BCM and error messages in the DTC? Most reliable way to do that is to disconnect the neg battery cable for at least 10 minutes.
What was the reason for installing a CLB? Preventative measure? Or were you experiencing the column lock symptoms and needed a CLB to get around the problem?? If the latter exactly what symptoms were you experiencing?
Did you check the battery to make certain the cable connections are clean, bright and tight.?? Starter wire also but remember that is electrically HOT.
Did you measure the battery voltage with a digital voltmeter directly across the battery posts with NO KEY in the ignition? What was the voltage measurement? Needs to be a minimum of 12.5 volts for the column lock electronics to function correctly? Don't bother with dash gage readings they cannot tell you the state of health of the battery. Weak battery or loose/dirty battery connections are the MOST COMMON cause of the column lock symptoms.
More when you tell us whether it is an A4 or Mn6 and answer the questions above.
It's a 99 A4 coupe and I removed the K harness but havnt checked the voltage
Old Jul 7, 2010 | 11:12 PM
jetstreamC5
Did you clear all the DTC's and error messages after you installed the CLB???
Yeah I reset the computer turned the key on same thing so I double checked everything reset it again turn the key on same thing.
Old Jul 8, 2010 | 01:40 PM
yamahajo's Avatar
yamahajo
Cruise-In 9-10-11 Veteran
St. Jude Donor '08-'09-'10,-'13
I believe in the Beer Fairy
I have been having this issue for nearly 3 years now.....
If the battery is good (you haven't said what you measured for voltage) then I suggest you try replacing the column lock relay. It is in the passenger footwell to the left of the fuse box and above the BCM.
Read the last 3 pages of posts in the Column Lock FAQ stickey. Poster Tracyz had a problem with his that turned out to be a bad relay. Your relay will be a differnt part number than yours because of the year difference in your car vs his 2002.
Not sure I've done that....will look into it.
Old Jul 9, 2010 | 03:07 AM
GM Fan's Avatar
GM Fan
Did you do the procedure to pull fuse 25 again for a 10 minutes from the fuse panel in the passenger footwell? I believe there is a section near the end of the instructions for the CLB that covers this situation. Or maybe I found it in these instructions only, don't recall. http://www.ls1howto.com/index.php?article=24 (covers this just before section 3 there). Either way, mine did this as well right after adding the CLB until I did that part of the reset procedure.
Old Jul 9, 2010 | 02:06 PM
jetstreamC5
It turns out it was th CL relay but I wanna thank you guys for all the help.
To Please help!!!! I installed clb still getting errors
