Please help with a M6 Shift Knob removal..
Old Mar 23, 2002 | 02:20 PM
bparker's Avatar
bparker
Default Please help with a M6 Shift **** removal..
How the heck do you remove this thing?!?! I have twisted counter clockwise and no dice - so what am I doing wrong??
:lol:
Thanks guys,
BP
Old Mar 23, 2002 | 02:34 PM
pdm's Avatar
pdm
Default Re: Please help with a M6 Shift **** removal.. (bparker)
Using a small flatblade screwdriver, pry out the shifter **** cap. You might want to put a rag between the **** and screwdriver so you don't mar the ****. Once removed, you will see a wedge that keeps the **** from turning. Using a pair of vise-grips or pliers, work the wedge back and forth pulling up at the same time. Again use the rag to keep from maring the ****. Once the wedge comes out, the **** can then be twisted off the shaft.
Old Mar 23, 2002 | 03:24 PM
te51cle's Avatar
te51cle
Default Re: Please help with a M6 Shift **** removal.. (pdm)
Take your time :(, breath easy :eek: , keep women and children clear - and preferably out of earshot - as that wedge can be a real pig to remove :boxing and you don't want them to learn any new words :cuss !!
Removing the factory shift **** is the most awkward 'simple' task to do on the car. :crazy: But its well worth it :yesnod: I did the mod the morning after getting the car home and I'm much happier for it. :cheers:
Old Mar 23, 2002 | 03:29 PM
robiferretti's Avatar
robiferretti
Default Re: Please help with a M6 Shift **** removal.. (te51cle)
i wish i had a picture of the tool i used, but itmade the process very easy, it fit right aruond it an in between the plastic so that when i pulled it forced it right out :cheers:
NOt that any of what i just wrote helps you in any way :smash:
Old Mar 23, 2002 | 03:32 PM
Fast Mover's Avatar
Fast Mover
Be Careful removing the pin. I was too anxious and rushed causing the pin to break off making a simple job a complicated one. Go slow and gently(but firmly) loosen it upwards.
good luck!
Old Mar 23, 2002 | 03:49 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Re: Please help with a M6 Shift **** removal.. (BRADS C5)
clamp a pair of visegrips onto the pin, then use a hammer and gently tap the visegrips up to release the pin.
works like a charm! :cheers:
Old Mar 23, 2002 | 04:08 PM
flynbludream's Avatar
flynbludream
Default Re: Please help with a M6 Shift **** removal.. (RPOZ4Z)
Spraying a little WD-40 at the base of the pin won't hurt either. Take your time and it will come out.
Old Mar 23, 2002 | 04:35 PM
NYtoCA's Avatar
NYtoCA
Default Re: Please help with a M6 Shift **** removal.. (flynbludream)
Yes, take your time! the second time i did it i was rushing and started chipping the t-steak all over the place....I had no choice but to drill the whole thing out which left such a mess....I was not happy but it was because i was rushing. It also didn't help that when i inserted it the first time i really stuck it in there.
Old Mar 23, 2002 | 05:59 PM
SteveL2's Avatar
SteveL2
This should help, a how-to for the shift boot, but it includes how to remove the shift ****. http://temp.corvetteforum.net/c5/ste...t_install.html.
Also, if you have trouble getting the pin out of the shifter, I think this link shows a perfect solution: http://forums.corvetteforum.com/zerothread?id=260932
Good luck. :cheers:
Old Mar 23, 2002 | 06:06 PM
Scruffy's Avatar
Scruffy
It's not as complicated or difficult as it sounds. Once you remove the plastic shift pattern (as mentioned above, gently pry up with a flat balde screwdriver) use two flat blade sscrewdrivers (1 on each side of the T) and pry both sides of the metal T up together. You don't have to force it hard. Comes out easy every time. :cheers:
Old Mar 23, 2002 | 08:52 PM
bparker's Avatar
bparker
Thanks for your help everyone :cheers:
I am crackin up @ myself as I assumed that was to be one of the easiest things to do on a car..
Anyway, mine was in there SUPER TIGHT and I used two screw drivers to equally apply "lift" pressure from both sides and it gradually worked its way loose...
HaHa - that one alomst got the best of me - as I was getting PISSED by the time I got that sucker out..
BP
Old Mar 23, 2002 | 09:10 PM
MySea6's Avatar
MySea6
Default Re: Please help with a M6 Shift **** removal.. (Scruffy)
Works everytime :cheers:
To Please help with a M6 Shift Knob removal..
