Help with Code 0357 on a 1998
Old Jul 10, 2010 | 10:59 AM
jack01's Avatar
jack01
6th Gear
Default Help with Code 0357 on a 1998
I have a 1998 Vette with 80000 miles and the code P0357(ignition control #7 circuit) comes up now and then and I reset and it is good for a time. I decided to change the plugs and wires and still have the same problem. I changed the coil for cylinder 7 with cylinder 5 and the same code came up P0357. Please help, thanks.
Old Jul 10, 2010 | 11:34 AM
lucky131969's Avatar
lucky131969
Inspect the wiring, especially where the harness goes around the bracket for the knock sensor plug. If nothing is obvious, you will have to remove the connector from the PCM, and check the resistance to ground on ignition #7 circuit.
Old Jul 10, 2010 | 11:41 AM
jack01's Avatar
jack01
6th Gear
Where would the knock sensor bracket be located? Thanks for you help
Old Jul 10, 2010 | 12:32 PM
lucky131969
Behind the left fuel rail (see below). Since this is a common chaff area, I have protect the wire bundle.
To Help with Code 0357 on a 1998
