Creaking suspension, input needed
To rule out the swaybars, which seem to be a common source for annoying sound, I disconnected the drop links. Sound is still there.
It mainly happens when the suspension movement is larger than normal, like going over a steep creast at high speed. Normal driving or going over speed bumps it's all ok. I also often I get it during parking when the steering is used to the end postions, but only if the car is moving. When turning the wheel when the car is stationary there is no sound or only a very faint, no difference engine on or off.
All the busihings seem to be ok. It's stock busihing, not the T1 ones. I've tried to lube them but no differnece. I noticed that when jacking the front end up the sound is very present when one front wheel is lifted "alone". The sound is there both going up and down, so to say.
I've tried to bounce the front end buit since the T1 suspension is quite hard I can get maybe 1" movement, but still no sound. I noticed that when both front wheels has been lifted and the car is lowered back to the ground the noice is very noticable, but after bouncing the front a few times it goes away until the next time the front is lifted.
Anyways, the sound is more of a creaking sound and doesn't sound like a squeaking bushing or similar, but it is definately suspension movement related. Sometimes I can even feel the creaking through the floor/pedals.
Any ideas? It is starting to drive me crazy.
I can't understand why the sound is only present if the car has first been lifted. It then then goes away after a few bonces on the fender. While driving it happens on large suspension movements or during parking. Car has ~35k, it's well taken care of and not abused. T1 shocks are basically new with maybe 2000 street miles and a few HPDE laps.
Outta curiosity, did you have tires replaced right before you noticed this? I had new tires put on it, shortly after I started hearing the noise....
Lemme know if you found anything out!
http://forums.corvetteforum.com/c5-t...all-joint.html
http://forums.corvetteforum.com/auto...hat-to-do.html
Every oil change is a good interval.
I started doing this w/ my wife's Honda and its CV boots on the advice of a friend after an expensive replacement, sold the car in 2005 with over 150K on the odometer having not replaced another CV boot. Swaybar endlink bushings still looked new also.
EDIT: Here's the link http://forums.corvetteforum.com/auto...hat-to-do.html
It sounds like your bushings are worn/damaged and binding on compression...time for replacement.
