Turning signal light
Old Jul 12, 2010 | 05:40 PM
ignatkor's Avatar
ignatkor
Default Turning signal light
Today noticed my right turning signal wasn't working. I changed the bulb and it still did not work, looked at the wires and seems like everything is alright there. What else can it possibly be?
Victor
Old Jul 12, 2010 | 06:04 PM
2EZ 2SPD's Avatar
2EZ 2SPD
I had the same problem and had to replace my corner lenses the heat from the bulb over time cracks the plastic and water got in and put corrosion in the socket. Look at the top of the lens over the bulb and see if it cracked up.
Old Jul 12, 2010 | 06:11 PM
rws.1's Avatar
rws.1
melted housings are a common problem that results in corroded sockets and sometimes shorted sockets....
check out the socket and replace if necessary.
To Turning signal light
