oil pan
Old Jul 13, 2010 | 01:52 AM
ru8up's Avatar
ru8up
3rd Gear
Default oil pan
do you have to drop motor to change oil pan gasket on c5 ? can you get one piece gasket on by unbolting oil pan ?
Old Jul 13, 2010 | 11:18 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
You don't have to remove the engine, but you do have to remove the front subframe. This means you'll have to support the engine. Be careful not to overtighten the the 2 rear (long) bolts on the pan. I've seen these bolt holes stripped before.
Old Jul 14, 2010 | 12:36 AM
ru8up's Avatar
ru8up
3rd Gear
thanks for the info....
To oil pan
