C5 kick down problem
Old Jul 14, 2010 | 07:03 PM
turgutsenol's Avatar
turgutsenol
4th Gear
Default C5 kick down problem
Hi,
I have a 1998 C5 with A/T at 23.000 miles on it. It shifts perfectly up (1-2-3-4) and down (4-3-2-1) during normal drive. However, when I kick down at 4th or 3rd gears around 1.500 rpms, it directly jumps to 2nd or 1st gears, increasing suddenly the rpm up to 4000-4500. What would be the problem. I appreciate your comments and advises. Thanks.
Turgut
Old Jul 14, 2010 | 07:46 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
That would be a pretty drastic fault, and there should be codes stored. Have you checked?
Old Jul 15, 2010 | 12:29 AM
soggysailor's Avatar
soggysailor
when you jump on it are you putting the peddle to the floor? Try modifying your driving. Use a quick 1/2 throttle instead of a "floor it" style. This seems to give you that 1 gear down shift and that quick acceleration without dropping into 1st. It may take some practice and restraint but I find it works rather well.
Old Jul 15, 2010 | 07:48 PM
turgutsenol
4th Gear
I live in Turkey and I am afraid this is a rare car for this country: I'll try to find a mechanic who would work on software.
Old Jul 15, 2010 | 07:53 PM
turgutsenol
4th Gear
Thanks for the tip. I'll give a try tomorrow and inform you about the result. But I am afraid there is something wrong with selecting the right speed/gear combination. This only happens on kick downs.
Old Jul 15, 2010 | 10:18 PM
BigGun's Avatar
BigGun
Agree. Sounds like your car is doing what it is supposed to do.
Old Jul 15, 2010 | 10:29 PM
Trios's Avatar
Trios
Thankfully, on a C5 Corvette you don't need anyone or anything to check codes.
Here is the procedure to have the car nicely list off all codes for you on the driver's information center (DIC).
http://www.c5forum.com/ayc/dtcdic.php
Old Jul 17, 2010 | 04:47 PM
turgutsenol
4th Gear
Thanks, I'll immediately work on this site.
Old Jul 17, 2010 | 05:42 PM
PETE O.'s Avatar
PETE O.
To C5 kick down problem
