Electrical Problem? Help!
Old Jul 14, 2010 | 09:36 PM
Raggtop's Avatar
Raggtop
Default Electrical Problem? Help!
A friend in the club is having a problem with his C5. When he turns on the blinker to go right his blinker flashes really fast and his traction control goes on and off as his blinker blinks. Our resident mechanic thinks it is a ground problem and its bleeding back through what ever circuit it can. Maybe someone else has had the same problem.
thanks in advance
Old Jul 15, 2010 | 08:42 PM
Raggtop's Avatar
Raggtop
Default ttt
ttt
Old Jul 16, 2010 | 08:01 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Anything is possible. I would first suggest checking out the lamps on the side that's blinking fast as well as cycling the hazard switch several times and see what changes. Since he's losing the traction control, I would be pulling the codes and see what's there.
To Electrical Problem? Help!
