headlight not opening
Old Jul 16, 2010 | 09:24 PM
declan's Avatar
declan
Default headlight not opening
I put hid lights in my vette a couple years ago and all worked until this week. I always had to put them on high beam to close ( the hid lights are just low beam) now i cannot get the drivers sides light to open, the passenger side opens fine. Can someone please help with this problem.
Old Jul 16, 2010 | 09:34 PM
KCvetteowner's Avatar
KCvetteowner
Pull the rubber cap off the headlight motor and turn top of the motor with your fingers while gently pulling up on the headlight assembly. This will get you going.
You need to have someone turn the lights on/off while you stand there and see if the motor moves (probably a gear broke) or the motor doesn't move (motor broke or electrical issue getting power to the motor).
