Powder-Coating
Old Mar 24, 2002 | 04:13 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Powder-Coating
I have my calipers diassembled and am taking them to the shop tomorrow :D
For those that have done this, how did you close off the cylinders....ie, apply proper "Foreign Material Exclusion" during the painting process?
I assume y'all closed off the entire port and not just the hole feeding the fluid :eek:
Old Mar 24, 2002 | 05:05 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Re: Powder-Coating (Mean Green 2000)
I did it the easy way............. I bought Z06 calipers! :D
Old Mar 24, 2002 | 05:30 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
that works if you want red ;) :D
Old Mar 24, 2002 | 09:01 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
:cheers:
Old Mar 24, 2002 | 11:21 PM
chuckster's Avatar
chuckster
Mark, I'd like to think that the Powder Coater has something to plug the holes. If you come up with your own design just make sure it can withstand the 450 degree temps.
I'd like to see em when they are done... :cool:
Old Mar 25, 2002 | 12:29 AM
SAXN8R's Avatar
SAXN8R
They guy that powder coated mine had these cork shaped rubber or urethane thingies.... :crazy: ...they plugged the holes with that.....he should have somthing.
Old Mar 25, 2002 | 08:20 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Powder-Coating (chuckster)
thanks...I was thinking the same thing about the temps :eek:
don't worry about that :D
Old Mar 25, 2002 | 12:48 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I seem to recall that Eastwoods sell a set of various sized plugs specifically for that purpose. In fact, they sell a complete powder coating set up.
Old Mar 25, 2002 | 03:44 PM
John Nowak PE's Avatar
John Nowak PE
Default Re: Powder-Coating (leadfoot4)
Yes, Eastwood does sell a complete PowderKote kit as well as the "high temp" plugs. They also sell a "high temp" fiberglass masking tape.
Mean Green 2000: your PowderKote guy should have the plugs and/or tape to keep the powder out of the proper areas. If not, then he should be able to easily get them. You could make your own; just like was mentioned above, make sure they can withstand 450 degrees. Another option is to look at the "low temp" PowderKote product. This stuff works/looks the same as the regular stuff but cures at around 250 degrees. For calipers, this should work fine; many have used regular auto paint on them with no trouble ;) And, the lower temp may make it easier to find stuff to "plug the holes".
BTW, the Eastwood plugs are made from high temp silicone and are generally red in color.
Hope this helps!
:cheers:
Old Mar 25, 2002 | 03:48 PM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: Powder-Coating (RPOZ4Z)
I did it even easier and bought some Hi-Temp engine paint and masked off the inner fender well and body with blankets and newspaper and then spray painted them. I then hand painted the letters with factory touch up paint. I have raced on the track and driven in stop and go traffic and my calipers have not chipped, cracked, or faded.
Old Mar 25, 2002 | 06:27 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: Powder-Coating (John Nowak PE)
thanks for all the help guys, really appreciate it :cheers:
now if I can just get him to come close to DBGM :D
Old Mar 25, 2002 | 11:32 PM
John Nowak PE
I believe that PowderKote does have a dark green color; won't be exact, but should get kind of close. Or, talk to your PowderKote guy; you can have "custom" colors created (I've heard they can duplicate almost any color). The only down side is cost; you have to purchase a whole "brick" of the custom color.
I would think that PowderKote's darkest green with the "micro prism" additive, you would get real close to DBGM :)
Good Luck!
:cheers:
Old Mar 26, 2002 | 05:49 AM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Good Luck!
:cheers:
:cool: thanks :cheers:
To Powder-Coating
