A/C Compressor going bad...
Old Jul 18, 2010 | 12:13 AM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
Default A/C Compressor going bad...
My C5 has over 80K miles and yesterday the A/C compressor began making a horrible noise. After searching the forum I found RoccoC5's YouTube video and write up. Awesome write up by the way. Anyway, mine sounds just like this maybe worst when the A/C is running. I'm pretty sure it needs to be replaced. Okay so while that's out, is there anything else I should replace (tensioner, idler pulley)?
Also, it looks like the harmonic damper is wobbling. Is this normal, or shall I replace it as well?
Thanks.
Old Jul 18, 2010 | 02:24 PM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
Anyone...
Old Jul 18, 2010 | 08:31 PM
rws.1's Avatar
rws.1
The harmonic dampener should not wobble... change it.
Hand spin the pulleys... if they spin freely and woblle free they are fine and do not need changing...
BUT if they wobble or fell gritty... change them
Old Jul 19, 2010 | 12:14 AM
flynbyu2's Avatar
flynbyu2
St. Jude Donor '10
Put the C6Z06 compressor on that thing. The A/C will be a LOT faster!
Sorry for the bad luck though...
Old Jul 19, 2010 | 07:08 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Make sure you change the accumulator also.
Old Jul 19, 2010 | 07:34 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yes on the harmonic balancer as it'll cost you a whole lot more if it comes off the crankshaft.
To A/C Compressor going bad...
