Squeek under hood
Old Jul 19, 2010 | 11:25 AM
harleyvette's Avatar
harleyvette
Default Squeek under hood
There is a squeek under the hood of my 98 c5. How can i tell which belt is makeing the noise?
Old Jul 19, 2010 | 11:34 AM
dougbfresh's Avatar
dougbfresh
Take one at a time off and run the engine for a few moments.
Old Jul 19, 2010 | 12:26 PM
FirethornC5's Avatar
FirethornC5
I recently had this same problem. Replaced both belts with Gatorbacks and both idlers also.
Once I removed both belts, I spun both idlers by hand and they sounded like rollerskates.
GM has a TSB for the Accessory Idler (not the A/C Idler) for a distorted shield problem. Their idler comes with the shield.
Once I replaced both idlers, I torqued the bolts to GM specs.
Noise gone!
To Squeek under hood
