Replacing Fuel Filter the ugly way
Old Jul 20, 2010 | 12:41 PM
jaybar's Avatar
jaybar
Default Replacing Fuel Filter the ugly way
Changing Fuel filter the Ugly way.
By way of background check out the thread at
http://forums.corvetteforum.com/c5-t...post1574750812
The problem started when some of us were unable to remove the line from our fuel filter (line going to the fuel rail). Many forum members offered very good suggestions, it is just that mine and maybe some others have a major problem and did not respond to the "correct methods".
When I gave up on the proper way to do it I determined it was time to get ugly. In looking at the replacement filter I could see the spring clips
were held in by a "ridge" on lip of the fitting. So I popped the fuel line out of the holder toward the engine to give me some wiggle room. Then you can work
the filter around the brake lines and get it down to just above the exhaust pipe.Now you can get ugly. I took a side cutter and pinched the lip till i cut it. I tried to
bend up some metal, my plan was to work my way around the entire lip but I took a close look and decided I might be able to get an ice pick inside and pop the
spring out of the lip. Well that is what I did the filter fell off the line, leaving the spring in place on the line. Just for fun I put my tool on the line and tried to
remove the spring by it self. Still no go I had to pry up the tabs and slide it off.
In summery, I played around with the removal of the fuel line for a total of 4 hours over three days. I even put it all back together once and said F*** it, I don't need a new filter.
So if yours doesn't come off as advertised, save time and get ugly with it and move on to more important work.
Old Jul 20, 2010 | 04:22 PM
FASST LN's Avatar
FASST LN
Loosely paraphrased from Ving Rhames, "I'm going to get medieval on its ***".
Once removed, I am going to burn this thing. Since it's been infused with gasoline for the past decade, I have no doubt it will ignite easily.
Thanks for posting Jaybar!!
And congrats!!
Old Jul 20, 2010 | 04:47 PM
timritchieblue's Avatar
timritchieblue
[QUOTE=FASST LN;1574757310]Loosely paraphrased from Ving Rhames, "I'm going to get medieval on its ***".
And congrats!! [/QUOTE
pics please
Old Jul 20, 2010 | 05:49 PM
Patches's Avatar
Patches
Holy crap! That is ugly! Nothing like home-based engineering protocols.
Old Jul 22, 2010 | 09:02 PM
FASST LN's Avatar
FASST LN
For a while, I didn't think it would burn:
Then I stabbed a hole in the side and tried it again...with better results:
Old Jul 22, 2010 | 09:24 PM
timritchieblue
thanks, fire, fire
Old Jul 22, 2010 | 09:42 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
Great pictures.
Old Jul 22, 2010 | 09:49 PM
73 LS-4's Avatar
73 LS-4
Nice Fire
Pat Kunz
Old Jul 22, 2010 | 11:32 PM
wcsinx's Avatar
wcsinx
Yeah, mine was the same way. I could not get that stupid line to release no matter how I manipulated the release tool. I ended up cutting a slot through the fitting with a rotary tool and then opening it up with a screwdriver.
Old Jul 23, 2010 | 07:13 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
While doing that, did you give any consideration of creating a spark around a GASOLINE filter??
Old Jul 23, 2010 | 09:16 AM
wcsinx's Avatar
wcsinx
Yes I did. And there were sparks a plenty. To clarify, I didn't actually cut into the line. I cut the lip of the fuel filter fitting just enough so that I could slip a screwdriver into it and split it open lengthwise. Once you split it a little, the circlip opens up, and the pressure is released off the fuel line.
And I had a fire extinguisher handy.
Old Jul 23, 2010 | 02:20 PM
UncleFodder's Avatar
UncleFodder
Tiki torch!
To Replacing Fuel Filter the ugly way
