Right Side Window Removal help?
Old Jul 21, 2010 | 10:00 AM
VettePal's Avatar
VettePal
Default Right Side Window Removal help?
Need ? Answered ? How Do I Remove Motor From The Regulator???
Old Jul 21, 2010 | 01:23 PM
tsts's Avatar
tsts
You don't, everything comes out in one piece. After removing window, disconnect plug to motor then unbolt assembly and remove all of it through the big opening in the door (it kind of folds up).
Old Jul 21, 2010 | 01:32 PM
Tech's Avatar
Tech
Most of that's correct except for the "you don't" part. You certainly can just replace the motor, once the regulator/motor assembly is out of the door.
Old Jul 21, 2010 | 03:25 PM
dougbfresh's Avatar
dougbfresh
Many of the ones I've done in the past are RIVETED to the regulator, you have to drill them out and pop-rivet them back together.
To Right Side Window Removal help?
