C-5 Transmission Slipping
Old Jul 23, 2010 | 05:42 PM
michaelrschultz's Avatar
michaelrschultz
2nd Gear
Default C-5 Transmission Slipping
My C-5 transmission slips sometimes between 1st and 2nd after the temperature reaches over 180 degrees
Old Jul 24, 2010 | 11:33 AM
99 vett babycar's Avatar
99 vett babycar
do all the usual things - check fluid level ,check for leaks,etc.
As you probably know the A4 is the weak link in your drive train.Its a good bet that your 1-2 clutch pack is starting to go. Either get it checked out, add a trani lub that's designed to limit slipping and get ready to call RPM transmissions. Sorry
