C5 Temperature -- worried!
Old Jul 23, 2010 | 06:50 PM
Heinekev's Avatar
Heinekev
1st Gear
Default C5 Temperature -- worried!
Hello everyone!
I typically drive a Land Rover Discovery, so I'm used to vehicles that overheat. Anyone who has owned one understands why I'm super-paranoid to the temperature gauge in any vehicle I drive nowadays. While the Rover is in the shop (rear ended-bleh), I'm borrowing a C5 from my Mom. It's her baby, obviously. She drove it off the showroom floor and has put 161,000 miles on it since.
Today, I noticed the temperature was creeping well past 220 -- it seemed to level out around 240. Should I be worried? As a precaution, I replaced her serpentine belt (it was squeaking), but I'm wondering if more needs to be done. I don't typically drive this vehicle so I'm not sure if this is normal for it. The outside temperature in Louisville was 101 degrees today, so I'm sure that contributed, and the temperature spiked while in heavy rush-hour traffic.
The radiator fan kicks on and the coolant level is fine.
I've done a little digging and have seen references to Z06's on track day reaching that temperature, but this was 20-30mph heavy traffic in a city. Ambient temp 101.
Thanks!
Old Jul 23, 2010 | 07:23 PM
Last C5's Avatar
Last C5
240 is a little high. On a hot day the 220 mark is about what most C5s run at or a little below. Since the car has so many miles I would check the radiator to make sure it's clean and hasn't picked up 160K of road trash. (or a single plastic bag)
Old Jul 23, 2010 | 07:54 PM
99 vett babycar's Avatar
99 vett babycar
in stop and go traffic, on a really hot day 240 is just bearly on the high side. have you checked to see if you have and trash or debrie blocking your radiator?
Old Jul 23, 2010 | 09:41 PM
AverageVetteNut's Avatar
AverageVetteNut
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
it was 96 here today and REALLY humid... sitting in traffic, mine would bump past 220 to almost 230ish... then would jump back down to around 200 moving around thru traffic. I've been worried about the same thing, but it's seeming to be relatively 'normal' from everything I've been reading here.
I've checked mine for debris and such. might do a coolant flush here soon.
To C5 Temperature -- worried!
