replacing the ac compressor
Old Jul 23, 2010 | 07:42 PM
hatewhatownsyou's Avatar
hatewhatownsyou
Default replacing the ac compressor
my compressor locked up today, has anyone replaced it themselves?
how hard is it to(it looks like a major pain)
anyone have an idea how much a shop would charge?
also, is there a fuse that i can pull out to make sure i dont acidentally turn the ac on?
Old Jul 23, 2010 | 09:45 PM
minitech's Avatar
minitech
Search "RoccoC5 a/c" and there will be a nice pdf writeup with pics to take you through it.
I just went through the change and it is not too difficult.
Old Jul 24, 2010 | 05:51 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
do the accumulator also, save yourself some grief as a precaution.
Old Jul 24, 2010 | 08:31 AM
LoneStarFRC's Avatar
LoneStarFRC
No warranty on the compressor without installing a new one.
Old Jul 24, 2010 | 09:18 AM
hatewhatownsyou
does anyone have any input about how i can disable the compressor from accidentally turning it on? i dont have any hookup on a vacuum pump, do i really need it or can i have a shop do that part?
i dont think im going to fix it till this winter
Old Jul 25, 2010 | 12:01 PM
Gr8Wht's Avatar
Gr8Wht
CF Veteran
St. Jude Donor '10-'12, '25
If you don't want the compressor coming on then turn off your A/C system inside the car. I'm replacing my compressor right now, about half way done. I plan on taking it to a shop, who took my freon out, to do the vacuum and add freon. Good luck.
Old Jul 25, 2010 | 07:56 PM
vetteguy98's Avatar
vetteguy98
I have the same situation. Chevy dealer in Shalotte NC wants $1250 for the job. In the little bit of research that I have done, that seems like the way that I am gonna go! The parts are about $500 but the labor looks intense!
Old Jul 30, 2010 | 12:48 PM
dmarkshark's Avatar
dmarkshark
I am in the process of getting my compressor changed out. Less than $800, new one. I use a guy I found on Craigslist that works from home. Hes really good (27 years in the business) and I trust him. He has worked on my cars several times, all good! You might look around and see if you can find someone like this. He has his limits, but what he does, he does well.
Old Jul 30, 2010 | 12:52 PM
minitech's Avatar
minitech
There is a connector on the clutch on the compressor. Pull that off and it shouldn't engage. Can reach down to pull it or take off the passenger tire to see it and get to it easier
Old Jul 30, 2010 | 07:07 PM
memphis_vette's Avatar
memphis_vette
just take the belt off for the ac clutch
To replacing the ac compressor
