AC Won't Turn On - Only 1 HVAC Code
Old Jul 24, 2010 | 10:46 AM
BTow1105's Avatar
BTow1105
Default AC Won't Turn On - Only 1 HVAC Code
I have a 2000 C5 coupe. I just had headers and a midpipe installed on the car and after that, my air conditioning was fine.
I brought it to a shop to have them adjust some clamps on a lift. After leaving, the air conditioning no longer goes on.
The actual air system will work, but when I push the A/C button, the light goes on for ~2 seconds (without blinking), and then goes off.
My only HVAC code is 'B0333 H C', which is an open outside air temp sensor open' code. My external air temp always reads 69*F, which has never been an issue before this. I had this code since I purchased the car and the AC worked fine the whole time.
All the shop did was turn two clamps and then ziptie a wire harness thats located near the collector on the headers. We don't think that wire harness had anything to do with the A/C, but I guess maybe it did.
Anyone ever have this happen? Maybe it's the battery for all I know lol.
Old Jul 24, 2010 | 01:09 PM
00Corvette's Avatar
00Corvette
I've answered this in detail in about 4 other threads this week...
http://forums.corvetteforum.com/c5-t...errerid=228945
http://forums.corvetteforum.com/c5-g...errerid=228945
and then do a search using my username and look for one of the most recent threads I started titled "couple bullet points about AC actuator"...
I'm pretty sure your issue is the passenger side.
Old Jul 25, 2010 | 04:50 AM
BTow1105's Avatar
BTow1105
Ended up being that my headers were touching the AC line and put a hole in it -___-
To AC Won't Turn On - Only 1 HVAC Code
