Help- DIY diff swap
Old Jul 26, 2010 | 06:01 PM
Rdrcr's Avatar
Rdrcr
Cruising
Default Help- DIY diff swap
have new diff. want to remove old one from housing and replace with new. '98 C5. purchased Quaife diff. want to try it myself. i am very mechanical inclined. any instruction or other info to assist me?
Old Jul 26, 2010 | 07:19 PM
cptinjak's Avatar
cptinjak
Remove from the housing?
Assuming you have a complete pumpkin you are trying to swap out, simply follow a clutch removal how-to like this one and when you get the driveline lowered down, throw a stand under the trans, lower the cradle off from the differential, undo the bolts that hold the differential to the trans, and pull it off.
Old Jul 27, 2010 | 05:01 PM
Rdrcr's Avatar
Rdrcr
Cruising
i want to change the differential ( the inside of the housing ). Not the whole unit. Only the part the ring gear is attached. Any hoe to instruction I can tap into?
Old Jul 28, 2010 | 12:02 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You need special tools to rebuild the differential
http://forums.corvetteforum.com/c5-t...ain-shaft.html
I'd drop Rick a PM.
To Help- DIY diff swap
