Headers and X-pipe
Old Mar 25, 2002 | 05:32 PM
wave_3's Avatar
wave_3
Active Streak: 90 Days
Cruise-In III Veteran
Default Headers and X-pipe
Right now I have Corsa Indy's and am looking to buy Long Tube Headers and an X-Pipe. Is there any combo that does not require welding, I would like an "easy" bolt on install.
Old Mar 25, 2002 | 06:28 PM
99 Corvette's Avatar
99 Corvette
Default Re: Headers and X-pipe (wave_3)
FLP has a bolt on kit http://www.flpexhaust.com :cheers:
Jerry
Old Mar 25, 2002 | 07:03 PM
vstella's Avatar
vstella
Most Long tube headers are manufactured to be welded, but if you have a good exhaust technician I'm sure they can put something together for you.
Check out my homepage for TPIS header and x-pipe / NO cats /Corsa Indy exhaust install pics..It will give you an idea of finished product :yesnod:
BTW....Install the x-pipe up as close to headers as possible..It will build ALOT of low end torque for you. Great mod!! :cheers:
Old Mar 25, 2002 | 09:50 PM
Chris@SD's Avatar
Chris@SD
Default Re: Headers and X-pipe (99 Corvette)
I agree. We have been using the F-body kits for some time and they are great!!! The C5 kit should be no less. Check them out and see what you think? If you are interested, give me a ring.
Thanks,
To Headers and X-pipe
