LS1 vs Z-06 bottom ends?
Old Jul 29, 2010 | 12:09 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Default LS1 vs Z-06 bottom ends?
Is the Ls-1(1999) bottom end the same as a early Z-06 bottom end? If not what is the difference? My goal is to replicate the "Z" motor power (or more) with a swap of intake, heads, cam, headers and a aftermarket air inlet system with out having to disturb the bottom end. Here is a time for you oppinionated guys to sound off
Old Jul 29, 2010 | 12:52 PM
cdkcorvette7's Avatar
cdkcorvette7
Not sure about the bottom ends being the same, but I can tell you for absolutely certain that with a new intake, heads, cam, headers and inlet you will be able to easily surpass stock Z06 power if you want to.
Old Jul 29, 2010 | 01:25 PM
BrentC5Z's Avatar
BrentC5Z
IIRC, the LS6 block has a different casting with "windows" for crank case ventilation. Thus the 6500 RPM redline.
To LS1 vs Z-06 bottom ends?
