C5 Corvette Auto Transmission problem Help
Old Aug 1, 2010 | 03:49 PM
mpetrovic's Avatar
mpetrovic
5th Gear
Default C5 Corvette Auto Transmission problem Help
I have a 98 C5 corvette. I was driving today and as I was accelerating the RPM's were going up but no movement. I down shifted to 2nd and it would drive. I put back in Drive as i slowed down and it would move but if I give it more gas the RPM's go up but no movement????
mpetrovic's Avatar
mpetrovic
5th Gear
Old Aug 2, 2010 | 04:47 PM
BigGun's Avatar
BigGun
This is a really hard one....your 3\4 clutch pack is shot so you need to have the trans rebuilt or replaced.
Old Aug 2, 2010 | 06:16 PM
jrose7004's Avatar
jrose7004
There must be an echo in here!
Old Aug 7, 2010 | 08:10 PM
mpetrovic's Avatar
mpetrovic
5th Gear
Thanks. I have RPM sending me a Level IV transmission
Old Aug 7, 2010 | 08:15 PM
mpetrovic's Avatar
mpetrovic
5th Gear
I meant Level V transmission
Old Aug 13, 2011 | 04:54 PM
SmoothDog0's Avatar
SmoothDog0
Default 1998 c5 with 124,000 miles same problem
i have a 1998 c5 with 124,000 miles same problem, the shop i brought it to suggested changing the solenoid for 3rd gear, flushing the fluid because there was no signs of metal shavings in the pan, however that cost was 660.00 and was not guaranteed to fix the problem, what is everyones opinion here?
Old Aug 13, 2011 | 10:24 PM
cdkcorvette7's Avatar
cdkcorvette7
So... You have an automatic right? If you run through the gears manually when you can get through 1 and 2 the car runs fine but when you shift into D the rpms will increase when you accelerate but your car will not get up to speed?
If that's your situation you need a tranny teardown and rebuild. If they are going to open it up anyway have them look to see if anything else is broken while they're in there... GL
Old Aug 14, 2011 | 07:51 PM
99 vett babycar's Avatar
99 vett babycar
call RPM
To C5 Corvette Auto Transmission problem Help
