replacing balancer need help!
Old Aug 4, 2010 | 10:32 PM
PewtVette's Avatar
PewtVette
Yep, pin the thing (easy & cheap) and use an ARP bolt and you'll have peace of mind.
Old Aug 5, 2010 | 08:11 PM
futuretech's Avatar
futuretech
thanks guys
Old Mar 14, 2011 | 11:54 PM
69_427_SBC's Avatar
69_427_SBC
Resurrecting this thread to ask some related questions (and since it's a good resource).
I'm about to replace the balancer on my '03 Z with a Powerbond Race 10% underdrive model. The car is essentially unmodified and very rarely sees a few drag passes, otherwise just daily driven.
My questions:
1) Is it worth pinning the crank on a stocker?
2) Someday, if I decide to go forced induction or change balancers again, do I need to re-drill and pin every time?
3) If I do buy and use one of the drill-yourself 1/4" key kits, and I eventually buy a keyed balancer, will it be compatible or will I have to once again drill and key?
I'd obviously like to avoid a bunch of notches in the crank that I don't need... you guys have thoughts?
Edit: forgot to mention I'll definitely be using an ARP bolt rather than the torque-to-yield. Not sure if that affects the situation.
Old Mar 15, 2011 | 12:16 AM
chevylad's Avatar
chevylad
My questions:
I would pin it if you plan on supercharging the engine, but running an underdriven pulley balancer will underdrive the supercharger. If you mount another balancer you can reuse the same pin. It's easy to add a pin once the balancer is off. I'm running a Summit SFI balancer with 8 grooves and a keyway. It fit on both a pinned crank and the new crank I have with key. I would also use a harmonic balancer installation tool to avoid putting so much stress on the crank thread. I made one out of all thread and welded a nut to the end, but you can buy them on this forum just as well.
Old Mar 15, 2011 | 12:29 AM
69_427_SBC's Avatar
69_427_SBC
I think the plan would be to upgrade to an 8-rib belt drive setup if I were to supercharge, which would require a new, keyed balancer. So if I can reliably do an un-keyed replacement now, it saves me ending up with two key slots in the crank later. Is any of this making sense? (I'm a bit short on sleep)
Old Mar 15, 2011 | 10:48 AM
corvettebob1's Avatar
corvettebob1
If you do the pin correctly you won't have any problem switching balancers, use the ATI type that drills perpendicular into the crank.
