Exactly which O2 sensors do I need?
Old Aug 2, 2010 | 02:16 PM
waddisme's Avatar
waddisme
Default Exactly which O2 sensors do I need?
Getting odd codes from o2 sensors, so I was thinkg about repl seeing I do not know how old they are anyway. Motor is LS2 in '02 Z06 with FLP headers. Currently there are only 2 sensors before the cats. If I understand things correctly, then I would need the rears? Would that be the heated ones $40.50 for Delco, or the other ones $90.50 Delco? TIA.
Old Aug 2, 2010 | 11:22 PM
kp1's Avatar
kp1
You're going to have to give more info.
When did the codes set and what was done to the car if anything, prior to setting the codes? Did the car ever run as it sits w/o setting an 02 code?
Old Aug 3, 2010 | 08:39 AM
waddisme's Avatar
waddisme
Car had been running fine. I found some shorted wires in the pigtail that goes to the MAF and fixed them so no codes. I still wouldn't mind changing the O2s just so I could have a back up at the track. I didn't put my headers on, so I am not sure which ones I need - the post catalytic ones or pre-catalytic. From my search, it seems everyone moves the rears to the fronts.
Mods are in the signature.
To Exactly which O2 sensors do I need?
