Do these spark plugs look right? oil on plugs. PICS
Is your intake dry? open the butterfly on your throttle body and stick a long q-tip or something similar and swab the intake and see if any oil is in there; hows your breather/pvc system? Any oil in the hose?
Yea. I have the intake off. Looking for vacuum leaks and changing out oil sender along with fixing hvac line. Gunna clean everything up.
The intake and throttle body have oil in them. The PVC hoses alot have oil in them
That maybe where your oil issue is coming from then, get a catch can and install it in-between the pvc and the intake connection then drive for a few hundred miles and see if your problems persist.
take the gaskets off then you could use brake parts cleaner, I do not think it will harm the intake.
That oil on the plugs isn't a good thing. Valve seals or rings would be my bets if you have it on 7 plugs. Valve seals are more likely if the car runs pretty good and doesn't smoke.
how much oil does it burn per change?
With 145k if you're not burning more than a half quart..prolly not too bad yet.
Well, the oil in the intake tract is both a good and bad sign; bad in that you are getting oil into the intake and cylinders but good in that if that is where the oil is coming from, it should be a relatively easy fix with a catch can. Now the 2nd catch is, why are you pushing so much oil into the pvc system? It could just be a catch can remedy or you could have positive pressure in the crankcase. With the engine running, open the oil fill cap and see if you have a lot of air coming out of the oil fill hole. If you do, then you may have a ring problem but you would also have a smoking car too so I doubt that the case. My guess is that it will either be excessive oil getting into the pvc system with a catch can being the remedy or you have bad valve stem seals. Try this, hold the car in a gear and accelerate then let off the gas and decelerate while leaving the car in gear (dont push in the clutch if you have a 6 speed) let the engine do the braking. While you are decelerating, look in the mirror and see if you are smoking on decel or have a friend watch as you drive by. If so, your valve stem seals are bad.
Here is my "spark plug" post with pics showing what my old plugs looked like for comparision.
http://forums.corvetteforum.com/c5-t...lug-gurus.html
Charlie
#33
i do have an oil leak but i dont know from where. it is a very small leak that leaves a couple drops a night.
#34
ill have to wait until i get the car back together. im sending my radiator and condenser in to be flushed and pressure tested. im also fixing my hvac line while the intake is off. i drained my oil and i found one small shaving of metal on my magnetic oil drain bolt. probably about 1 cm long
#37
That was my thought too but he said the deposits were white not silver. I suspect that your assessment that it is metal maybe right though.
#38
and if you're not burning a noticeable amount of oil each change, I wouldn't worry about it. If you have the heads off already anyway or the long block out of the car by all means...do the valve seals at least.
Do a compression check for the rings also as it's cheap/easy...I highly doubt you've got a bad ring though.
How old did say those plugs were? Age and miles? Did you run those plugs at all before your mail order tune with any mods? Bad O2 sensors with those plugs?...that type of stuff could have caused a lean/rich condition that fouled the plugs all up. I just don't see how it could be burning much of you don't even lose a quarter or half quart at each oil change...are you going til the DIC says 10 percent life or less?
#39
make sure to get a new accumulator and check your orifice valve
Dryer too
#40
plugs are about 1-1.5 years old and about 40k miles. yes i had those plugs in b4 my tune. should i switch back to iriduims since that is what my tune is for? i got 2 new front o2 sensors ill be putting them in this week. my car is back together but i still have my intake manifold off as i am waiting for a oil pressure sensor. i change oil every 5k miles
