steeing column lock
Old Aug 8, 2010 | 09:12 AM
videoslave's Avatar
videoslave
7th Gear
Default steeing column lock
I read the sticky and checked my car over every thing seams ok.The problem started after i removed passenger door motor.Then i started car and moved it to see better.I got the code to remove key for a few seconds and restarted car then got the steering column lock car will start and move a few feet and stall (the recall has been done on the car) i put the new window motor in the window now works but i still have steering column lock code and can not get rid of it i also put another battery in it
