Info On Blaclwing Intake
Old Mar 26, 2002 | 04:47 PM
HOCKEY's Avatar
HOCKEY
Default Info On Blaclwing Intake
I just ordered the Blackwing Donaldson Intake and the hood seal. This is my first add on MOD as my C5 is a complete stock car. Is that all I need to do for the intake upgrade and no type of concerns or adjustments needed besides driving habits........ I seen post about water getting inside the filter. Thanks
Old Mar 26, 2002 | 04:51 PM
Untouchable00's Avatar
Untouchable00
Default Re: Info On Blaclwing Intake (HOCKEY)
This is a typical intake setup, however, if you want you can always get the front screens (where the fog lamps are located). These screens allow the cold air to enter the engine compartment as you drive. In addition, you can cut your radiator shroud where the filter rests, this, with the screens, hood seal and Blackwing would give you the most air intake. But what you have now should be pretty efficient, too.
Old Mar 26, 2002 | 06:50 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
I have it on my 99 FRC, & just ordered it for my 01 Vert, I added the hood seal on my FRC & will do the same on my Vert, I've had no problems on the FRC, ( disconnected the battery ) & did the Idle relearn. I positively could tell the difference on the FRC !, that's why I ordered it for the Vert ! I haven't had any water issues, of course I don't drive in "deep" water! My Vettes do not say "Bayliner" or "Mercruiser" on them anywhere.... :lol:
Old Mar 26, 2002 | 07:42 PM
HOCKEY's Avatar
HOCKEY
Default Re: Info On Blaclwing Intake (3VETTES@HOME)
What do you mean by idle relearn?
Old Mar 26, 2002 | 08:17 PM
3Vettes@Home
Cruise-In V Veteran
Idle relearn tells the system through the MAF sensor how much air flow is coming into the engine, disconnect the negative battery terminal while installing filter, re-connect, then take car out for an aggressive drive...the system will relearn the amount of air coming into the engine, there are several posts currently on this subject. I did his on my 99FRC w/out problems, I have no surging or spark knock ( more air means leaner condition) I'm sure a better explanation can be found on the Forum :cheers:
Old Mar 27, 2002 | 01:08 AM
HOCKEY's Avatar
HOCKEY
Thanks for the info and hope to do when it comes in by Friday.
Old Mar 27, 2002 | 01:17 AM
borba's Avatar
borba
Where do you find the idle relearn procedure with the information on pulling the proper fuse and other important information? I heard if you do this procedure the relearn will happen in a short distance instead of the longer relearn route. :yesnod:
Old Mar 27, 2002 | 10:16 AM
blackvette1's Avatar
blackvette1
The Blackwing is a great filter. I switched to it from another aftermarket intake system and the car felt much stronger and dynoed much higher. You don't need to disconnect the battery or do the idle relearn when installing it. It is not necessary the computer learns very quickly. I swapped my on and took it for a spin and could feel the difference right away. Also, my car is a daily driver and we get plenty of heavy rain here in Dallas and I've never had a problem. :crazy:
Old Mar 27, 2002 | 07:33 PM
levettegrl's Avatar
levettegrl
My corvette club gave me a blackwing filter as a gift-we put it on last night and didn't disconnect the battery-car drives great!!!!
-Leslie
Old Mar 27, 2002 | 08:38 PM
3Vettes@Home
Cruise-In V Veteran
Default Re: Info On Blaclwing Intake (levettegrl)
Sorry...I had forgot to mention, I also changed my MAF ends at the same time, that's why I did the Idle relearn :crazy:
Old Mar 27, 2002 | 10:02 PM
HOCKEY's Avatar
HOCKEY
Help me out here what is MAF?
Old Mar 27, 2002 | 10:20 PM
EvilDeed's Avatar
EvilDeed
Cruise-In II Veteran
MAF = Mass Air Flow. It has a sensor that detects air flow and adjusts fuel automatically to attain optimum ratios.
An alternate to the hood seal is a front mask. It was my choice, but obviously isn't everyone's preference.
Jim
Old Mar 28, 2002 | 07:04 AM
Driller's Avatar
Driller
St. Jude Donor '10
I drive with a Blackwing in the rain all of the time. No problems. :yesnod: :yesnod: :yesnod:
Old Mar 28, 2002 | 05:29 PM
HOCKEY's Avatar
HOCKEY
Default Re: Info On Blaclwing Intake (Driller)
Thanks for the info and will have on Friday.
Old Mar 29, 2002 | 12:02 AM
flipm's Avatar
flipm
Tom,
I did the exact same mods on my 2002 Convertible, and it worked great... I gained 4mph in the 1/4 and I shaved .4 seconds (though I attribute that to driver improvement... the times can get lower.
You may notice that the engine sounds "deeper" when you open up the throttle. The intake makes it sound more muscular and less "revvy". I had not realized how much the intake could change the tone of the engine...
Old Mar 29, 2002 | 01:40 PM
Orsadude2's Avatar
Orsadude2
I just added the Blackwing and hoodseal. I also added a Corsa Indy Exhaust. Before I installed the Blackwing I dyno'd
the car with the Corsa Exhaust. Max h.p. was 295 at rear wheels. Then I added the Blackwing. Tore out the MAF screen
(battery was disconnected), then drove on the freeway around St Louis at various speeds, (usually fast). I immediatey
noticed the pickup. I drove approximately 45 miles. I went back to the dyno where everyone was eagerly awaiting my returen. I
did 2 pulls. First pull went to 305. Second pull as 312!!! I was amazed. The wing not only gave a big jump in H.P., I
I didn't get any "surges" others have mentioned.
:D
Old Mar 29, 2002 | 01:42 PM
RG in Dallas's Avatar
RG in Dallas
Elite Member
Cruise-In I Veteran
Cruise-In III Veteran
Default Re: Info On Blaclwing Intake (Orsadude2)
:D
Great results.:)
RG
Exit 28 Motorsports.com
"Home of the Blackwing":)
To Info On Blaclwing Intake
