Remove air pump ? what happens ?
Old Mar 26, 2002 | 04:52 PM
Guest
Guest
Posts: n/a
Default Remove air pump ? what happens ?
Hi every0ne, i just got my Silver TT that i bought from SW :-)
And new heads, cam LS6 intake is on its way from LPE along with a
PCM upgrade for my car.
I was wondering what happens if i just ripped out all this airpump
system, any errors on DIC ?
I know it is there to get a cleaner exhaust during the first two minutes after starting the car.
Anyone with insight on this ?
TIA
Old Mar 27, 2002 | 09:56 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Remove air pump ? what happens ? (c5norway)
I have removed the AIR Pump before and just blocked it off. The car runs fine, but just throws codes. The codes can be programmed out by a tuner or LS1 Edit. :cheers:
-Jeremy
Old Mar 27, 2002 | 12:29 PM
Face's Avatar
Face
Default Re: Remove air pump ? what happens ? (Godspeed)
How much does it weigh? Is there any other reason to remove it?
To Remove air pump ? what happens ?
