hood light ??
Old Aug 9, 2010 | 05:15 AM
tomlor611's Avatar
tomlor611
Default hood light ??
just got my 01 about a month ago,1st vette coming from a 07 shelby and loving it but i notice when i lift my hood the light on the under side doent work took cover off no bulb!anyone no what kind of bulb that is or a number and hopefully the other owner didnt take it out for a reason?
Old Aug 9, 2010 | 10:15 AM
mcgilles's Avatar
mcgilles
I don't know the bulb number but its the festoon style bulb but with the little hooks on the end rather than the cylindrical ends that clamp in. auto parts store should be able to find one for you. or you can upgrade, I put an LED into mine, more light and better light. looks nice now! also make sure that its plugged in, there's a connector attached to the radiator shroud below where the light is. I've heard of people unplugging this for car shows to keep the light from staying on, which is weird because mine turned off after 15 minutes all by itself...until I broke it and wired it hot all the time.
it uses a gravity switch to turn on and off, so you provide 12V to the housing at all times and the light only comes on when you raise the hood, there's a little canister looking device under the cover, that's the switch.
Old Aug 9, 2010 | 12:21 PM
lucky131969's Avatar
lucky131969
AC Delco p/n L561
Old Aug 9, 2010 | 01:39 PM
lwise4's Avatar
lwise4
Default bulb
The previous owner probably removed the bulb because on occassion, the mercury switch can stick and the bulb will stay on and run the battery down. I just unplug mine and can always plug it in when needed! You will note that the C6 does not have a under hood light. I WONDER WHY?
Old Aug 9, 2010 | 01:55 PM
tony car4a's Avatar
tony car4a
I agree. I took mine out for the same reason and just left the bulb under the plastic lens in the event I wanted to reinstall it.
To hood light ??
