No knock!!!
Old Aug 9, 2010 | 04:22 PM
theoz385's Avatar
theoz385
Default No knock!!!
Got a 99 vert with LS2 402 and for some reason I am not getting any knock what-so-ever. We try and force a knock and not even .0001 of knock, not even anything we can hear. The knock sensors are positioned behind the motor mounts on both sides with adaptor harness. Any ideas. Oh, and no codes. Thanks
Old Aug 9, 2010 | 04:42 PM
dougbfresh's Avatar
dougbfresh
???? If the knock sensors are working, why would you expect a KNOCK?
Old Aug 9, 2010 | 04:49 PM
theoz385's Avatar
theoz385
Good point! How do I test them to make sure they are working? Thanks
Old Aug 9, 2010 | 04:54 PM
dougbfresh's Avatar
dougbfresh
Put a scanner on it and graph the knock sensor output or the spark advance while you bang on the engine with a wrench close to the knock sensor(s). As you bang on it, the sensor should see your "noise" as a knock and change the timing.
Old Aug 9, 2010 | 05:14 PM
theoz385's Avatar
theoz385
Will try that. Thanks
Old Aug 9, 2010 | 06:52 PM
theoz385's Avatar
theoz385
No knock retard when tapping on the block next to the sensor. Bab harness, sensors? Checked both sides.
Old Aug 9, 2010 | 07:31 PM
dougbfresh's Avatar
dougbfresh
read this:
http://forums.corvetteforum.com/c5-t...esistance.html
To No knock!!!
