Compression Test Throttle Body Position
Old Aug 11, 2010 | 04:03 PM
Neil B's Avatar
Neil B
Default Compression Test Throttle Body Position
With the throttle-by-wire setup, is it necessary to manually prop open the throttle body when doing a compression test? I will be using a remote starter, fuel pump disabled, and ignition key in the OFF position.
Thanks. --Neil
Old Aug 11, 2010 | 04:15 PM
dougbfresh's Avatar
dougbfresh
I would think so, hard to do a compression test with no air to compress.
Old Aug 11, 2010 | 04:24 PM
Neil B's Avatar
Neil B
It definitely makes compression with the throttle body in it's base position. But is the compression reading affected by not having the throttle body wide open? Is there a right and a wrong way to hold the TB open? I don't want to mess up the TPS.
To Compression Test Throttle Body Position
