P0153/P0154 Help with 02sensor
Old Aug 11, 2010 | 09:36 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
Default P0153/P0154 Help with 02sensor
A few days ago I had the P0410code for the air system check valves. I did the Bill Curlee cleaning and it hasn't come back so far.
Now, today, I had the P0153 and P0154 codes pop up with the check engine light. Those are both for bank2 sensor 1, passenger side front sensor. P0153 is slow response and P0154 is circuit insuffecient activity.
However, I have the LG streets which are now 3-4 years old. I think LG moved the rear 02sensors to the front and tuned out the codes for the rear?
So, my question is: Which one of the two sensors should I replace? Or, should I replace both of them on the passenger side? All ideas appreciated.
Thanks,
Jeff
Old Aug 11, 2010 | 09:42 PM
00Corvette's Avatar
00Corvette
The probably deleted the rears like you were saying. If both of your codes are for the passenger side bank, just replace that one. After 3-4 years it wouldn't surprise me to see one go bad..
Old Aug 12, 2010 | 02:10 PM
JeffC5's Avatar
JeffC5
I still have all 4 sensors in place. Also, with the headers don't they switch them from side to side? I'm getting confused as to which one this would be on my car.
To P0153/P0154 Help with 02sensor
