TPMS question
Old Aug 12, 2010 | 11:42 AM
kj217's Avatar
kj217
Default TPMS question
i am planning to replace my 99 C5 wagon wheel with some deep-dished wheels,,
is it possible to install TPMS sensors on the new set?
if not, is it possible to disable TPMS?
Old Aug 12, 2010 | 02:11 PM
kj217's Avatar
kj217
the wheels are used and are of some cheap god knows what brand,,
my friend offered them for free
is there anything i can look at to know if the sensors would fit?
Originally Posted by 8VETTE7
On the 2001 and newer C5's the TPMS can be turned off. (Z06's did not come with them installed) It cannot be turned off on the earlier cars.
As for the TPMS fitting a newer wheel, you need to ask that question to the manufacturer or tell us what wheels you are going with. Many different wheels are in use by forum members that can tell you their experience installing the TPMS.
Old Aug 12, 2010 | 02:14 PM
vetdude's Avatar
vetdude
So, they may not even be sized for a C5, is that what you're saying? You need to check the wheel offsets and bolt pattern before going through anymore trouble.
Old Aug 12, 2010 | 02:15 PM
kj217's Avatar
kj217
i will post the specs later,,
Old Aug 12, 2010 | 02:56 PM
kj217's Avatar
kj217
if i decided to only replace tires,, how to do so without missing with TPMS?
Old Aug 12, 2010 | 03:18 PM
my6thvette's Avatar
my6thvette
Any good tire shop should be able to do this for you. Just remind them of the TPMS and be sure that they install the wheels in the same location from which they were removed.
To TPMS question
