c5 ac blowing hot need HELP
Old Aug 15, 2010 | 08:28 AM
c5andfine's Avatar
c5andfine
Cruising
Default c5 ac blowing hot need HELP
2000 vette compressor clutch comes on. But only hot air comes out. A/C wont work if you change modes either, like defrost or at the feet , charge is fine but head seems high at 350 with a 40 #suction. I changed outdoor air temp senser with no luck .Please point me in the right dirrection thank you in addvance.
Old Aug 15, 2010 | 09:31 PM
wca_tim's Avatar
wca_tim
I know this seems obvious, but have you looked to see that the condensor was unobstructed? I recently found several large birds nests worth of crap in mine when the air wasn't working worth spit...
Old Aug 18, 2010 | 08:39 PM
c5andfine's Avatar
c5andfine
Cruising
i got it wow i almost gave up gauges were off by 25 # unit was low blowing fine now thank you all
Old Aug 19, 2010 | 02:55 PM
alanmtz's Avatar
alanmtz
so, you refilled with freon?
Old Aug 19, 2010 | 10:27 PM
c5andfine's Avatar
c5andfine
Cruising
yes i pulled a vacuum and weighed in the charge 1#.50 oz it works great very touchie now all i have to do is find the leak
Old Aug 19, 2010 | 11:23 PM
alanmtz's Avatar
alanmtz
Can you please give me instructions on how to do this, I'm slow when it comes to A/C. Thanks
To c5 ac blowing hot need HELP
