Changing a rim anythign special to do to sensor ?
Old Mar 27, 2002 | 10:18 AM
lostsoulny's Avatar
lostsoulny
Default Changing a rim anythign special to do to sensor ?
Hi all topic says it I am changing a front rim, I will be using sensor from old rim, anything special to be done ? thanks
Old Mar 27, 2002 | 02:24 PM
lostsoulny's Avatar
lostsoulny
Default Re: Changing a rim anythign special to do to sensor ? (lostsoulny)
anyone ?? I am having the tire remounted on a different rim, using sensor from the present damaged rim. Is there anything else I have to do ensure the sensor still functions ??
[Modified by lostsoulny, 1:24 PM 3/27/2002]
Old Mar 27, 2002 | 02:37 PM
motoracer's Avatar
motoracer
You may need to replace the gromit around the sensor, where it contacts the rim. I changed out all four wheels and one started leaking. It is worth the $2 for the gromit, just to not have the problem.
To Changing a rim anythign special to do to sensor ?
