Torque Specs for Rear Rotors
Old Aug 15, 2010 | 04:16 PM
Camaroguy22's Avatar
Camaroguy22
Default Torque Specs for Rear Rotors
What are the torque specs for the rear rotors? Thanks
Old Aug 15, 2010 | 04:18 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
Are you talking about the lug nuts? 100 ft/lbs - front and rear.
Old Aug 15, 2010 | 04:22 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
there are no torque specs specificly for the rear rotors, they are held in place by the wheels and lug nuts, as mentioned 100 ft/lbs. If you are talking the rear caliper brackets to replace or remove the rotors. its 125 ft/lbs.
Old Aug 15, 2010 | 06:19 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
there are none. The rotor is held down by the wheel and its lug nuts. 100 ftlbs.
Old Aug 15, 2010 | 06:31 PM
lionelhutz's Avatar
lionelhutz
Make sure you apply that 125ft-lbs to the bigger caliper bracket to spindle bolts. The little caliper to caliper bracket mounting bolts are muich less, likely around 30 ft-lbs or so, but hopefully someone can post that number for you too.
Peter
Old Aug 16, 2010 | 02:00 AM
Last C5's Avatar
Last C5
Peter
The caliper slide pin bolts get torqued to just 23 ft lb.
Old Aug 16, 2010 | 09:08 PM
MNCrystalRed2011's Avatar
MNCrystalRed2011
Old Aug 16, 2010 | 11:15 PM
lionelhutz's Avatar
lionelhutz
There's the toque, thanks.
Peter
To Torque Specs for Rear Rotors
