p0481 high fan
Old Aug 17, 2010 | 10:19 PM
da_vato's Avatar
da_vato
Default p0481 high fan
So Ive been noticing more and more evidence of a wreck and a S****Y mechanic doing the work. Well I find that the check engine light doesnt work (SOB). so anyways ways I pull the dash apart and switch out a bulb and the light stays on because of P0481. I had always wondered why i never heard the fan but the engine never did get hotter than 22*0 though. Ive changed out the relays and fuses are all good. So I hook up the scanner and try to command the fans to come on and nothing. Low fans come on now prob. So my dad pulls the relays and I command one more time and no voltage on command. So we use a jumper wire and fans come on screaming. so circuit is fine from relays to fans. However Im not to sure from pcm to relays. I doubt that wire could realy be messed with alone since it would be in a big bundle coming from the pcm harness. How often do the pcm's really go bad?
Old Aug 19, 2010 | 11:32 AM
da_vato's Avatar
da_vato
does anyone know exactly where the wire goes from pin 33? I tried to do a continuity test to the relay and nothing. I pulled the fuse box up and the wires are different leading to the relay. Pin 33 is dk blue and wires underneath the relay are brown.
Old Aug 19, 2010 | 11:38 AM
8VETTE7's Avatar
8VETTE7
Can't help with the path the wires take but here is the wiring diagram if you don't already have one:
Old Aug 19, 2010 | 11:44 AM
da_vato's Avatar
da_vato
I have that also, the dk blue wire does not go directly to the relay as the this says, some where the wire changes to brown (thats what I physically see)
Old Aug 19, 2010 | 02:11 PM
8VETTE7's Avatar
8VETTE7
I don't know what year your car is but according to the shop manual for my 04, the wires that plug into the ports F1, E10 and B3 on the bottom of the underhood fuse block C1 are Drk Green, Drk Blue and Lt Blue exactly as shown on the diagram. It may be possible that things are different on you year car or that you are looking at a block other than C1 or that someone has done some handi-work repairing wires without observing color coding....
Old Aug 19, 2010 | 02:56 PM
da_vato's Avatar
da_vato
This is an 02 and it was involved in a front end collision with the previous owner (craftyness is definitely a possibilty)
Old Aug 19, 2010 | 04:15 PM
8VETTE7's Avatar
8VETTE7
I suggest that there is a non-factory splice between the PCM and the Fuse Block.
Good luck with your problem determination........
Old Aug 19, 2010 | 11:15 PM
byronhunter's Avatar
byronhunter
This help? Find out what the wire color is in this slot.
Connector Part Information
15303513
68-Way F Metri-Pack 280 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A1
PNK
839
Ignition 1 Voltage
A2
Not Used
A3
BLK/WHT
451
Ground
A4-A5
Not Used
A6
PNK
639
Ignition 1 Voltage
A7-A12
Not Used
B1
PNK
839
Ignition 1 Voltage
B2
PNK
339
Ignition 1 Voltage
B3
Not Used
B4
BRN/WHT
419
MIL Control
B5
PNK
639
Ignition 1 Voltage
B6
ORN
340
Battery Positive Voltage
B7
ORN
340
B8
BRN
241
Ignition 3 Voltage
B9-B12
Not Used
C1
PNK
839
Ignition 1 Voltage
C2-C3
Not Used
C4
GRY/BLK
87
Cruise Control Resume/Accel Switch Signal
C5
PNK
639
Ignition 1 Voltage
C8
DK GRN
59
A/C Compressor Clutch Supply Voltage
C9
DK GRN
/WHT
459
A/C Clutch Relay Control
C10
WHT
375
Skip Shift Indicator Control
C11-C12
Not Used
D1
PNK
539
Ignition 1 Voltage
D2-D3
Not Used
D4
WHT
121
Engine Speed Signal
D5
PNK
639
Ignition 1 Voltage
D8
PPL
420
TCC Brake Switch Signal
D9
Not Used
D10
PPL
421
AIR Solenoid Control
D11-E1
Not Used
E2
PNK
839
Ignition 1 Voltage
E3
PNK
339
Ignition 1 Voltage
E4
GRY
397
Cruise Control On Switch Signal
E5
PNK
639
Ignition 1 Voltage
E6
BRN
241
Ignition 3 Voltage
E7
BRN
241
Ignition 3 Voltage
E8-E9
Not Used
E10
DK BLU
473
High Speed Cooling Fan Relay Control
E11
Not Used
E12
DK GRN
/WHT
465
Fuel Pump Relay Control
F1
DK GRN
335
Low Speed Cooling Fan Relay Control
F2
PNK
839
Ignition 1 Voltage
F3
LT BLU
20
Stop Lamp Supply Voltage
F4
DK BLU
84
Cruise Control Set/Coast Switch Signal
F5-F6
Not Used
F7
BRN
241
Ignition 3 Voltage
F8
Not Used
F9
BRN
436
AIR Pump Relay Control
F10
PPL
6
Starter Solenoid Crank Voltage
F11
PNK
239
Driver 36 Volt Reference
F12
BLK
150
Ground
Old Aug 20, 2010 | 12:15 AM
da_vato's Avatar
da_vato
That will be very useful. Thank you byron
Old Sep 8, 2010 | 12:35 PM
da_vato's Avatar
da_vato
This is my findings, I guess the fuse panel has a circuit board with in it.
Old Oct 4, 2010 | 03:03 PM
da_vato's Avatar
da_vato
well I replaced a PCM and all was well..... until I took a little trip this weekend the fault is back. I pulled the relayes and the contacts looked a little burnt so I sandpapered them and tried to command the fan through hptuners. It didnt want to come on at first but then I pulled fan3 relay and it worked just fine. I put a jumper and a probe to manually test but while I was holding the jumper I noticed the wire was getting really hot rather quick.
What kind of voltage/amps is fan 2 drawing?
Does is sound like there is a minor short somewhere?
Im assuming this is what killed the previous PCM
Old Oct 4, 2010 | 05:05 PM
lucky131969's Avatar
lucky131969
........sounds like you never had a PCM problem......
Doesn't sound like you used an appropriate size jumper wire. Even if you don't know exactly what the fan(s) draw, you can just look at the fan fuse rating.....to give you an idea.
Old Oct 4, 2010 | 10:00 PM
da_vato's Avatar
da_vato
The PCM for sure had a dead circuit. As soon as I figured out where the wire from the PCM popped out at I commanded with the HPtuners and no voltage so the PCM was dead. As soon as I replaced it all was great for about 150 miles. I hope youre right about the wire though
To p0481 high fan
