Oil Change
Anyway, you can make your own ramps out of 2X10 or 2X12 sections. Yes, jacks and jackstands will work IF you can get your floor jack under the car and IF (big if) you jack and support in the proper places. Otherwise you can do real damage to the car.
A further complication is the wonky drain plug location on the C5. It is at the front of the pan, which means to get a good drain the car should be level or, ideally, raised a little at the rear. If you were in central South Carolina I'd do it for you at my house. A possible alternative if you don't have the proper equipment as outlined above is one of the quickie oil-change shops that drive your car over a pit as opposed to using lifts. Fewer chances for car damage with the pits, but try to find a shop where someone actually gives a damn and is not trying to get you "in and out in 15 minutes". Good luck.
There is no need to raise the rear. The little oil left in the pan is not worth the time/danger of lifting the rear.
This is an EASY job that people like to compicate with their pedantics.
Use the oil GM, Porsche, Rolls, Ferrari, and Mercedes recommends.....Mobil 1
The main difference between Race Ramps and Rhino ramps are quality and performance. Its like comparing apples and oranges.
Race Ramps are cut from a solid block of high-density expanded polystyrene, not injection molded like the cheap ramps. They are then coated with a hybridized polyurea. What this means is that the ramps are incredibly strong and lightweight. As well they don't slide on the floor, even epoxy coated floors. The quality raw materials are expensive.
The angle of approach is 10 degrees, with optional extenders to reduce angles even further.
We have heard horror stories of Rhino ramps suddenly collapsing. Due to the Race Ramps construction technique, it is impossible to have catastrophic failure if the ramps are severely overloaded.
Race Ramps are made by Americans in Michigan, not in a Chinese sweatshop. So, labor is more expensive.
Do a search on this website and you will find a multitude of very happy users of Race Ramps, who feel the value they receive is well worth the cost of the ramps.
The "inexplicable" has been explained.
I assume there are designated jack points under the side rails. but where are the proper places to position the jack stands?
Not only does the air damn have to bend, but the front gets scraped, you can see how it is about to bottom out on the ramp.
Simple solution...
Just used some scrap wood, used finish nails to fasten the two pieces, and the bottom piece does not have to be that long, probably at least the length of the 2nd piece, it's like stairs.
No scraping or rubbing now.
The carpet (scrap) helps keep all of it from sliding like it can do on concrete.
Well, it only took 5 qts on that oil change, so the next change I went back to raising the rear a bit higher, and it took the 6 qts.
I use a big floor jack, put a thick phone book on it to help spread/cushion the load on the crossmember.
Yep, I use the Mobil 1 fully synthetic 5W30, buy the 5 qt jug, and one qt at Walmart, about $30 bucks or so, and get the AC Delco oil filter after hearing about Fram's filters sometimes having problems, $4.50 or so.
Got the car in 2003, and have never let anyone else change the oil, don't trust them!
